 Grand Trunk Western GP18
Author Previous Topic: C-424, RS-2 8 wheel drive? Topic Next Topic: AHM ALCO Jersey Central
Hypoponera
BQ23-7
 Posted - October 21 2006 :  5:44:35 PM Link directly to this topic  Show Profile  Add Hypoponera to Buddylist
Here are a couple photos of another rebuild. It started as another AHM GP18. I replaced the handrails with Athearn stantions and bent brass wire. I added wire grabs chassie mounted the couplers. The pilots were filled with sheet plastic and the steam generator equipment on the shorthood roof was removed. I stripped the paint and sprayed on the GTW colors. Markings are from micro-scale. The original motor was replaced with a can motor and single flywheel. Electrical pickup was changed to all wheel pickup.
http://hypoponera.tripod.com/hypoponeras_photos/index.album?i=2&s=1
http://hypoponera.tripod.com/hypoponeras_photos/index.album?i=3&s=1
 Country: USA  ~  Posts: 715  ~  Member Since: May 03 2006  ~  Last Visit: October 10 2026 Alert Moderator
MagnoliaAcademy
 Posted - October 21 2006 :  10:06:49 PM Link directly to this reply  Show Profile  Add MagnoliaAcademy to Buddylist
Hypoponera:
Perhaps it just the marque (I'm a sucker for Grand Trunk motive power), but I'm even more impressed here than with the NdeM Geep. This is very good modeling--a most impressive retrofitting of an AHM shell most would write off as a second-rate platform for reworking. Tip of the cap to you, sir! Let's see more.
Impressed in Magnolia
 Country: USA  ~  Posts: 446  ~  Member Since: December 09 2005  ~  Last Visit: October 28 2006 Alert Moderator  Go To Top Of Page
Hypoponera
BQ23-7
 Posted - October 21 2006 :  11:53:18 PM Link directly to this reply  Show Profile  Add Hypoponera to Buddylist
Glad you liked the GTW! I have no interest in the GTW myself. But I stumbled into a photo of this exact loco rolling past my house in Indiana. I decided I just had to have a model of it in my collection!
Hypoponera
BQ23-7
 Posted - October 23 2006 :  11:47:58 PM Link directly to this reply  Show Profile  Add Hypoponera to Buddylist
Here is a peek under the hood.
http://hypoponera.tripod.com/hypoponeras_photos/index.album?i=9&s=1
alcopj
 Posted - June 05 2008 :  02:10:52 AM Link directly to this reply  Show Profile  Add alcopj to Buddylist
Originally posted by Hypoponera - October 21 2006 : 5:44:35 PM
Were did you get that can motor and single flywheel set up from?
Thank's
 Country: USA  ~  Posts: 17  ~  Member Since: August 23 2007  ~  Last Visit: October 20 2009 Alert Moderator  Go To Top Of Page
 Posted - June 06 2008 :  4:59:39 PM Link directly to this reply  Show Profile  Add Alco Fan to Buddylist
I don't know how but I missed this post but I did. That is one handsome loco and it looks more like a P2K than AHM. Well crafted!
 Posted - June 06 2008 :  5:52:23 PM Link directly to this reply  Show Profile  Add romcat to Buddylist
Hey Mike:
I'll try and scan tomorrow, and send you a gorgeous MR (March `74) Cover shot of a GTW GP. It's in the old Green and Yellow paint scheme. Might make you want to repaint that GP!?
Edited by - romcat on June 06 2008 5:53:42 PM
Hypoponera
BQ23-7
 Posted - June 07 2008 :  1:33:27 PM Link directly to this reply  Show Profile  Add Hypoponera to Buddylist
The motor is from MicroMark tools. They sell it for $24.99. I got it on sale for $10. The flywheel was bought at the local hobby shop. I think it was made by NWSL. I think MicroMark sells the same flywheel.
I have found several good motors on ebay. While in the HO section, do a search for motors. You'd be amazed at the pile of new motors going for next to nothing. The AHM shell will hold a motor of about 20mm wide. A shorter motor would allow easy installation of a second fly.
Hey AF, I thought you had seen this one way back.
Romcat, love to see the photo. I think I had seen the colors and liked it, but couldn't find decals for it.
 Posted - June 07 2008 :  3:08:06 PM Link directly to this reply  Show Profile  Add romcat to Buddylist
Hey Ant-Man:
The decals are around... Don't know if they are GP specific.
 Posted - June 07 2008 :  4:48:39 PM Link directly to this reply  Show Profile  Add NickelPlate759 to Buddylist
Nice job on the Geep, Hypop. I thought the motor looked like the ones in the Micro-Mark catalog. I think my LHS sells them too. How does it perform? Good low speed?
Hypoponera
BQ23-7
 Posted - June 07 2008 :  6:28:18 PM Link directly to this reply  Show Profile  Add Hypoponera to Buddylist
The motor is great! Well worth $24.99. I'm just too cheap to spend that much when I know they put the motor on sale for half off atleast once a year. I usually buy 3 when they go on sale.
Motor specs:
5 pole, skew wound.
no load @12V: 9800 rpm and 0.06 amp nominal
Typical 24 gm-cm load @12V: 8755 rpm and 0.25 amp nominal
Stall torque @12V; 160 gm-cm and 1.50 amp nominal
The motor is perfectly sized to fit in the AHM hood. It's tight, but requires no sanding of the shell. Also, the twin shafts are 2 mm in diameter.
This loco performs very well. It is one of my "Atlas beaters"! It has a lower minimum smooth speed then an Atlas 6 axle GE. It's top speed is slower then stock AHM by a long ways.
alcopj
 Posted - June 07 2008 :  10:33:58 PM Link directly to this reply  Show Profile  Add alcopj to Buddylist
Motor specs:
5 pole, skew wound.
Originally posted by Hypoponera - June 07 2008 : 6:28:18 PM
How did you connect the shaft ends to the motor? Also, how did you mount the motor?
Thanks very much!
Hypoponera
BQ23-7
 Posted - June 08 2008 :  01:02:39 AM Link directly to this reply  Show Profile  Add Hypoponera to Buddylist
The spline shafts are either Athearn or A-Line. I use both interchangably. The motor is glued in place with clear silicon sealent. It holds the motor and absorbs some sound and vibration.
 Posted - June 08 2008 :  01:49:37 AM Link directly to this reply  Show Profile  Add NickelPlate759 to Buddylist
Those motor specs look great, so I'll keep it in mind for future projects. Mehano uses shafts and universals in their diesels that are clones of Athearn drive parts, except that they fit a 2mm shaft. That creates all sorts of possibilities. [^]
 Posted - November 19 2008 :  9:24:02 PM Link directly to this reply  Show Profile  Add Alco Fan to Buddylist
I had fun looking at your models again Mike.
 Image Forums 2001 This page was generated in 0.26 seconds. Powered By: Snitz Forums 2000
