[ Active Members: 0 | Anonymous Members: 0 | Guests: 64 ]  [ Total: 64 ]  [ Newest Member: yardmaster1954 ] Select Skin:
 Long roadbed track section wanted
Author Previous Topic: Thank you for the track Topic Next Topic: WANTED: Mantua 2-8-2s and 2-6-2s
 Posted - December 02 2009 :  01:11:18 AM Link directly to this topic  Show Profile  Add GoingInCirclez to Buddylist
Does anyone have a long (say 18" or so) section of old tru-scale track, or EZ track (if they even make that length?) or something they could part with?
Whenever I photograph longer cars or sets of cars, the sectional EZ-track I use sags at the joint (I use a cheap card table underneath). Using shims is cumbersome. A single long, solid track piece would be ideal. A wooden (or maybe even gray) one would be even better, as it would eliminate the roadbed blending into the trucks and frames on equipment.
If you can help I'd be most grateful... thanks!
Tyco Nut
 Posted - December 02 2009 :  01:57:12 AM Link directly to this reply  Show Profile  Add Tyco Nut to Buddylist
Maybe you could put a nice piece of wood underneath? Personally I'd use a scrap 2x4 or 2x6, plane it on all sides, run a router around for a decorative edge, and use a little spare stain to make it pop.
I'd even make you one if you like - just send me your address. Sagging card table would be a non-issue, and you could mount the track directly to the board permanently.
Rus
MM 1498
ICRAvatar
 Posted - December 02 2009 :  9:50:15 PM Link directly to this reply  Show Profile  Click to see MM 1498's MSN Messenger address  Add MM 1498 to Buddylist
I think you can buy 36" pieces of EZ track, although the roadbed is really just two 18" pieces fused together. The actual rails are 36" long.
I think I have a couple somewhere...hmmph time to go digging!
Oh, and it is the grey roadbed with nickle-silver track stuff.
- Matt -
Edited by - MM 1498 on December 02 2009 9:51:03 PM
