Is anyone else still having problems trying to post photos? I have alerted and emailed moderators of problem and have gotten no response. THIS IS REALLY AGGRAVATING AND A DISSAPOINTMENT!! When i try to post picture in every format available it always says file not allowed try file with extension. SITE HAS A MALFUNCTION. ALL MEMBERS REPLY PLEASE. There has to be something DONE SO THAT SITE WILL TAKE OUR PHOTOS AS ENCOURAGED BY ITS CREATOR
Posts: 2507 ~
Last Visit: October 21 2017
Hi. To make your picture show up in your message. Your picture must be a .JPG To add to your message, use the add attachment button. (Last button next to Zip Icon) When the window opens it says: Upload afile / add attachment. Click on browse button and locate where you have your picture stored. and highlite and click open button. Then click upload button. After it uploads. You need to click on "Note: Click here to display this image on your message." This will add your picture . Then you can type your message Or you can Type your message first and then add your picture. When finish click on preview to see your post before you post it. I will be looking to see your pictures. I have added a picture to this post. Good luck, Carl Numquam Immoderatio Satis Est (Too Much Is Never Enough )
Posts: 632 ~
Last Visit: June 21 2020
Originally posted by VintageHO - February 14 2006 : 03:11:02 AM
Posts: 2507 ~
Is there a setting that enables or disables the ability for a member to upload photos. My photo is a JPG (Dec16^22.JPG) and the site will not accept it following the above instructions. It states that the file type is not excepted. I notice that my HTML is off. does that have anything to do with it?Ray
Posts: 1285 ~
Last Visit: May 16 2019
I found that double clicking on the file name will give you errors. Open the file then upload as instructed. It should work. You might try lowering the resolution on your camera. I think the lower the better but I might be wrong.
Posts: 7 ~
Last Visit: March 24 2006
Hi Ray. HTML is off Should not make a difference. But, the name of your file might. In your post you mentioned "Dec16^22.jpg" The ^ might cause a problem. Try naming it without the ^ and see if it works also check the file size. It could also be too large. Carl Numquam Immoderatio Satis Est (Too Much Is Never Enough )
Posts: 632 ~
Thank you Carl [:)] That's what it was. That is the file name that my camera assigns to the photo. I will just have to rename them before posting. [:)] [:)] [:)]Ray
Posts: 1285 ~
