Posted - October 03 2015 : 09:17:44 AM
quote: quote: I love this vintage piece. The rubber band drive has a little delayed "sproing" action which carries it through circuit interuptions. The bands will dry out and rot if not loosened when not in use, I have found. Here is a short video clip of it in motion. https://www.youtube.com/watch?v=ijmQjglqnmg
Originally posted by Chops124Â -Â August 19 2014Â :Â 3:46:59 PM
I know I may sound like an idiot here but, um, how do you loosen up the rubber bands?
Originally posted by kovacste000Â -Â August 19 2014Â :Â 6:04:45 PM
Hey - I'm with Steve!! Nobody answered this.... I have 2 RDCs, and this thread has convinced me to get a couple of Hustlers too!!
..... But if I'm forced to pay more than $10 for one, I may shoot the seller!!! LMAO!!!!!!
Carmine - CEO, Engineer, and Chief Bottle Washer Pacific Belt RR, in HO Scale, Since 1975!
Posts: 82 ~
Last Visit: October 26 2015
Alert Moderator
Posted - January 01 2016 : 2:35:10 PM
By loosening, I mean to disconnect so they are not under tension.
Posts: 11193 ~
Last Visit: April 19 2024
Alert Moderator
Posted - January 01 2016 : 4:49:09 PM
quote:By loosening, I mean to disconnect so they are not under tension.
Originally posted by Chops124Â -Â January 01 2016Â :Â 2:35:10 PM
This is good general advice for storage of anything with rubber bands. Most bands are made of rubber that is susceptible to drying out or even dry-rotting when taut.
Been interesting to read about these drives. It seems that yes, they are good - if you take good care of them. A rubber band drive working well honestly doesn't surprise me after discovering that some CD drives use a rubber band drive to open and close the tray..
In the case of the RDC, though, I don't think just working well is good enough. I would suggest relocating the drive to the undercarriage if at all possible or else mounting it directly onto one of the trucks. Why do I suggest this, you might ask? To make room inside the thing for seats.
Posts: 750 ~
Last Visit: January 24 2024
Alert Moderator
Posted - January 01 2016 : 6:14:11 PM
Oh, I see. The thing is, I ended up getting a Proto 1000 RDC instead of an Athearn RDC, and so far, I'm impressed with it.
Posts: 3533 ~
Last Visit: January 11 2023
Alert Moderator
Posted - January 01 2016 : 6:55:36 PM
I DCC'ed an Athearn Hustler band drive switcher, it runs good, but I need to put the weight back in it, it kept derailing on switches on the club layout. I think if you're going to use one, remove the rubber bands when not in use. Since the shell pops off easy enough, it's easy to remove them from the motor shafts and let them flop around until you're ready to use it again, then pull them back over the motor shafts.
Posts: 3974 ~
Last Visit: January 11 2019
Alert Moderator
Posted - January 01 2016 : 9:32:57 PM
That was slick Jerry. Never would have thought you could DCC one of those things. Kudos there guy.
Posts: 865 ~
Last Visit: May 01 2023
Alert Moderator
Posted - January 03 2016 : 9:34:20 PM
quote:That was slick Jerry. Never would have thought you could DCC one of those things. Kudos there guy.
Originally posted by oldtimer52Â -Â January 01 2016Â :Â 9:32:57 PM
Well, actually this is a NWSL dual shaft motor, all I used of the original engine was the chassis and body and weights. I have foam pads under the motor insulating it from the chassis. I haven't tried to put the decoder into the shell yet, but that's coming. I was just testing the proof of concept that a rubber decoder engine would work. It amused my club members to no end. :)
Posts: 3974 ~
Alert Moderator
Posted - February 16 2016 : 6:41:33 PM
I popped on an Athearn rubber band drive Budd. Thing runs slicker than goose you know what.
Posts: 11193 ~
Alert Moderator
Posted - March 25 2016 : 11:42:02 PM
And here they be. Run sweet.
Posts: 11193 ~
Alert Moderator
